  • Nso 18 posts 87 karma points
    Aug 16, 2017 @ 13:34
    Nso
    Tags not working
    Using tags property and wanted to render it. It is giving back "System.String[]".
    Please help me out.
  • Alex Skrypnyk 6181 posts 24242 karma points MVP 8x admin c-trib
    Aug 29, 2017 @ 11:27
    Alex Skrypnyk
    Hi Nso
    What wrong with tags rendering you showed?
    Alex
  • Manish 373 posts 932 karma points
    Aug 29, 2017 @ 13:02
    Manish
    @if (@Model.HasProperty("tags"))
        string[] tagsList = Model.tags.ToString().Split(',');
        if (tagsList.Count() > 0)
            <ul>
            @foreach (var tag in tagsList)
                 <li>@tag</li>
            </ul>
  • John Bergman 483 posts 1132 karma points
    Aug 29, 2017 @ 19:21
    John Bergman
    If it is returning a string array, you would need something like this instead...
    @if (@Model.HasProperty("tags")) { string[] tagsList = Model.tags;
        <ul>
             <li>@tag</li>
        </ul>
  • Jeremy Holland 20 posts 103 karma points
    Oct 24, 2017 @ 23:26
    Jeremy Holland
    This is an issue for me in 7.7.3
    The object returned from a call to Umbraco.Field("seoKeywords") (which is a tags data type) is an IHtmlString, which contains the string "System.String[]" rather than an actual array of strings.
    What is the solution for this?
    EDIT: I was able to extract the tag datatype value using a strongly typed view and the following code: var tags = Model.Content.SeoKeywords.ToArray(); but I'm still confused as to why the Umbraco.Field method doesn't work
    MORE EDITS: Further testing using the CurrentPage object proves that I can get the tag datatype value using the following code: string[] tags = CurrentPage.seoKeywords;
  • William Charlton 171 posts 218 karma points
    Dec 29, 2017 @ 12:36
    William Charlton
    I have exactly the same issue. I had a very handy XSLT script in a V6 site which now doesn't work. Snipertags was great but that now doesn't work. So I tried the Razor example as Jeremy has done and I get the same "System.String[]" Has someone broken V7.7.6 in the name of progress?
    Does anyone have an example of built in Tags actually working in a late version 7??
    It isn't fixed so break it?
  • Rajmond Burgaj 5 posts 86 karma points
    Dec 29, 2017 @ 15:04
    Rajmond Burgaj
    You may use this syntax as below to get the tag array:
    var tagList = Model.Content.GetProperty("tags").Value as string[];
    Jan 03, 2018 @ 11:01
    William Charlton
    2
    I have replaced the selector used, as shown on https://shermandigital.com/blog/display-umbraco-tags-on-razor-templates/ I replaced Sherman's
    var tagList = Umbraco.Field("articleTags").ToHtmlString().Split(',');
    with
    I replaced "tags" with my property name "pageTags" (Sherman uses "articleTags")
    var tagList = Model.Content.GetProperty("pageTags").Value as string[];
    And to display the tags? The code from Sherman Digital works. Thanks Rajmond!
  • Biagio Paruolo 1621 posts 1914 karma points c-trib
    Feb 17, 2018 @ 15:12
    Biagio Paruolo
     string[] tags = CurrentPage.keywords;
     string keywordstags =   String.Join(",",tags);
