foreach (var item in sizecollection.OrderBy("Parent.wwwidth"))
@item.Parent.wwwidth
this returns an error "Sequence contains no elements"
this...
foreach (var item in sizecollection.OrderBy("Parent.Name"))
Does what you would expect and orders the nodes by their parents names.
all nodes in sizecollection has a parent with a nonempty property with the alias "wwwidth".
"error CS1977: Cannot use a lambda expression as an argument to a dynamically dispatched operation without first casting it to a delegate or expression tree type"
var id = Request.QueryString["id"];
var product = Umbraco.Content(id);
var sizelist = product.wwstr.ToString().Split(new string[] { "," }, StringSplitOptions.RemoveEmptyEntries);
var sizecollection = Umbraco.Content(sizelist);
OrderBy selfmade property on parentnode razor
Im trying to order a list of nodes..
this...
Does what you would expect and orders the nodes by their parents names. all nodes in sizecollection has a parent with a nonempty property with the alias "wwwidth".
Thanks in advance.
I would do it using LINQ like this:
Assuming that wwwidth is an int. If it was a string you'd use
GetPropertyValue<string>instead.Hello Dan
Your answer gives me:
Hi Simon,
How are you declaring sizecollection? Is it a typed object or a dynamic object. I suspect it is dynamic based on the error you are getting.
Nik
Hi Nik
Its dynamic.
So, if you use a non-dynamic way to initialise
sizecollectionthen my code should work, I think. So try:That worked.
