Textbox & Textarea macro parameters are not being saved
I'm trying to add a macro to a page along with setting some parameters. I've added some Textbox parameters, that don't get saved between page publishes. I've tested also with Textarea properties and these have the same effect of not saving.
I've tried adding Decimal parameters and this saves...!?!
If you can´t wait until this get fixed, the what you can do as a work around right now is find these files in your installation and make the following changes to them.
This is with a new installation of Umbraco 7.6.5.
Any help appreciated!
Hi Sam and welcome to our :)
It´s sems to me that you have hit into this issue http://issues.umbraco.org/issue/U4-10360
https://github.com/umbraco/Umbraco-CMS/pull/2131/files
Hope this helps,
/Dennis
