  • ThomasBrunbjerg 90 posts 182 karma points
    Sep 05, 2017 @ 09:02
    ThomasBrunbjerg
    Can't use @model with @inherit
    I've implemented Entity Framework into my project, since I need to insert some data via a form to a custom table in my SQL database.
    I've scaffolded all the CRUD views and have a button that links to the create view. This all works well and fine, but I need the create view to use the Master template that contains my header, navigation and footer.
    In my create view I need to import my model, but I am unable to both use the @model and the @inherit keywords in the same file, so I am unable to inherit the master template.
    Is it not possible to use Entity Framework with Umbraco? Do I need to create a partial view or Macro?
    Sep 05, 2017 @ 09:05
    Alex Skrypnyk
    Hi thomas
    You can use Entity Framework with Umbraco, you can use what you want with Umbraco :)
    There is a PetaPOCO mini ORM in Umbraco, often it's enough.
    Alex
    Sep 05, 2017 @ 09:12
    ThomasBrunbjerg
    Thanks, but where would i place my markup for the Create view to make it inherit from my master template?
    I cannot use @model and @inherit in the same file.
    Sep 05, 2017 @ 13:51
    Alex Skrypnyk
    But you can use:
    @inherits UmbracoViewPage<ModelClass>
    Sep 05, 2017 @ 14:10
    Nik
    Hi Thomas,
    Alex's explination is correct, you would use @inherits UmbracoViewPage
    Both of Umbraco base view pages (UmbracoViewPage and UmbracoTemplatePage) allow you to specify the model, although the UmbracoTemplatePage insists that your model inherits from Umbracos RenderModel object.
    Nik
  • Paul Seal 524 posts 2890 karma points MVP 7x c-trib
    Sep 05, 2017 @ 13:44
    Paul Seal
    '''@inherits UmbracoViewPage
