  • Stefan Joseph 19 posts 120 karma points
    Sep 05, 2017 @ 09:18
    Stefan Joseph
    Best method for replicating content across a website?
    Looking for some help in regards to replicating content across the website I'm working on.
    I want the content editor to be able to create a list of products, ideally using a macro picker, containing a:
    • Title
    • Short Description
    • Link
    I would then like to re-use these listed products in various situations i.e 'Similar products'.
    What is the best method in order to achieve this?
  • Georgs Bormanis 25 posts 122 karma points admin hq c-trib
    Sep 05, 2017 @ 11:22
    Georgs Bormanis
    Hey Stefan!
    Why don't you just create a document type with these properties and then allow that document type to be used under all producs?
    Then you will be able to create content with that doc type wherever you need to.
    Or am I misunderstanding something? :D
    Sep 05, 2017 @ 11:41
    Stefan Joseph
    Not 100% sure that would accomplish what I need..
    so lets say I have a Products Page : The editor can create a product listing via a macro picker - he creates oranges and apples.
    When a user is on the apples page, I'd like a section that says:
    "You may also like these products"
    There I would like to list the product/macro I created earlier - oranges
    I would like to apply this to things like case studies and news listings etc. Hope this gives you a better idea!
    Sep 05, 2017 @ 11:47
    Georgs Bormanis
    Oh then I misunderstood you, sorry.
    Davids solution should work like a charm! :) #H5YR
    Stefan Joseph
    Not a problem Georgs, appreciate the help!
  • David Armitage 510 posts 2081 karma points
    Sep 05, 2017 @ 11:44
    David Armitage
    101
    Hi Stefan,
    1. Create a docType to contain your list of products. Maybe docType: Products
    2. Create a docType for the actual product. Maybe docType: Product
    3. Create a content node for products and add a few product nodes below this.
    This will be a central store for your products
    1. Now create a multi-tree node data type called featuredProducts and set the start node to be your product list node.
    2. You can now add this to which ever page or node you want. For instance you could add a featured products data type to the homepage and then render the products in the frontend with razer script.
    I have done something similar a load of times. Here is an example of some razor script that does exactly this.
    In my case I have a list of popular job searches rather than in your case products.
    @if (Model.Content.FeaturedJobPopularSearches != null)
                    foreach (JobPopularSearch jobPopularSearch in Model.Content.FeaturedJobPopularSearches)
                        <div class="item col-md-4">
                            <h3>
                                <a href="@(siteSettings.JobListingsPage + jobPopularSearch.SearchTerm.FormatForUrl() + "/")">
                                    @jobPopularSearch.Title Jobs
                                </a>
                            </h3>
                            @if (!string.IsNullOrEmpty(jobPopularSearch.Description))
                                <p>
                                    @jobPopularSearch.Description.ToString().Truncate(140);
                                </p>
                            <hr />
    Hope this helps.
    Kind Regards
    David
    Stefan Joseph
    Think this is exactly the sort of thing I was after, appreciate the help David!
    Sep 05, 2017 @ 11:58
    David Armitage
    No problems. Let me know if you have any trouble. Happy to help.
