Upgrade to 7.6.1 error loading macro partials using Content.Url
I'm in the process of upgrading our website to Umbraco v7.6.1 via NuGet package. The upgrade worked, but I get runtime errors on pages that use macro partials where I'm using code to access the Umbraco content API to return data. Any help is greatly appreciated.
Microsoft.CSharp.RuntimeBinder.RuntimeBinderException: 'System.Array' does not contain a definition for 'Url'
I adjusted the code to use @item.linkUrl.Url wherever I'm getting Umbraco content. Do you recommend code rewrite or disabling Property Value Converters?
@foreach (var item in selection) { <div class="col-sm-4 loan-option"> <section class="item-img-wrap"> <a href="@Umbraco.Content(item.linkUrl).Url" class="item-img" style="background-image: url(https://assets.newamericanfunding.com@(Umbraco.Media(item.backgroundImage).Url))"></a> </section> <section class="option-wrap @item.name.Replace(" ", "-").ToLower()"> <div> <h3 class="item-title"><a href="@Umbraco.Content(item.linkUrl).Url">@Html.Raw(item.itemTitle)</a></h3> <h4 class="item-desc">@item.itemDescription</h4> </div> </section> </div> }Hi Jason
Problem can be with Property Value Converters, please have a look:
https://our.umbraco.org/documentation/getting-started/setup/upgrading/760-breaking-changes#property-value-converters-u4-7318
Please, disable Property Value Converters or just rewrite your code, I think it should be :
Alex
Thank you, Alex!
@item.linkUrl.Urlwherever I'm getting Umbraco content. Do you recommend code rewrite or disabling Property Value Converters?Jason
I recommend code rewrite, Property Value Converters is an awesome feature of Umbraco.
Alex
Okay cool. Thank you for your time!
Jason
You are welcome, Jason.
Alex
