  • K.Garrein 164 posts 629 karma points
    Sep 07, 2017 @ 13:55
    K.Garrein
    Macro not working in grid layout RTE
    Hey all.
    Umbraco version 7.6.3 assembly: 1.0.6361.21154
    I have a macro that just does a simple logged in check and then should display "Allowed" or "Not allowed".
    When I insert the macro in the grid layout as a macro, it works fine.
    When I insert the macro in a RTE in the grid layout, then it doesn't work... I'm pretty sure I have seen that work before, any ideas as to why it wouldn't work?
    See following screenshot (green is macro in grid layout, red is same macro in RTE in grid layout): enter image description here
    The code:
        var loginStatusModel = Members.GetCurrentLoginStatus();
        if( loginStatusModel.IsLoggedIn )
            <p>Allowed</p>
        else
            <p>Not allowed</p>
    Sep 07, 2017 @ 14:13
    K.Garrein
    Is this the same issue? http://issues.umbraco.org/issue/U4-6206
    Thanks.
    Sep 07, 2017 @ 14:54
    K.Garrein
    101
    This workaround described on the above issue page solved my problem: https://gist.github.com/rasmuseeg/a1b3deed488e544ccc62
  • Rune Grønkjær 1372 posts 3103 karma points
    Oct 24, 2018 @ 12:52
    Rune Grønkjær
    How is this even a problem? Thanks for the solution. Still a problem in v 7.12.3
  • Jeroen Oostwouder 104 posts 300 karma points
    Jul 14, 2020 @ 14:08
    Jeroen Oostwouder
    Well, hold on to your hat... it still is in 7.14
