  • Stephen 94 posts 255 karma points
    Sep 13, 2017 @ 23:46
    Stephen
    Umbraco Grid CSS Issues and Html.Raw problems
    Hi All,
    A couple of questions please.
    1. I have read about this quite a bit, and just want to see if I missed any recent developments. But it would appear that the CSS files you can include in a Grid page (setup in Data Types) are only applied to RTE content, and not to anything else on the grid page.
    I am using the off the shelf macro editor (within the row, in the grid), and the CSS is not applied to that. Is there a new and better way to do this other than applying CSS to the entire backend or doing inline css (which is what I am currently doing, but that's a maintenance nightmare)
    1. As stated above I am using the "off the shelf macro editor (within the row, in the grid)". There has been a little modding so I can also include RTE with the macro (but that's unrelated). The problem I am having is that for example this: "
      some text
      " is rendering as "<p>some text</p>" (displaying as escaped html).
    Before you all shout use Html.Raw, I did. @Html.Raw(Model.MacroParameters["oText"].ToString()) still renders as "<p>some text</p>".
    The code I am using to get round this (and it works) is: var oText = Model.MacroParameters["oText"].ToString(); .... @Html.Raw(HttpUtility.HtmlDecode(oText.ToString()))
    but I suspect I have missed something somewhere and this is overkill, can someone please advise.
    I am also commenting on this because through out all my searches I couldn't find anything Umbraco related about this (the escaped characters), not inside macros anyway.
    I am not going to be surprised if you come back to me saying I have answered my own questions, and that's not a problem. I just want to be sure I am not missing anything.
    Stephen
