I'm using the fanoe theme but with modified css. It is all really nice and good. But I still have one problem that I cant figure out.
When i add a Banner Headline the H1 tag gets a style attribute with values from somewhere but i Cant figure out where it's coming from. Does anyone here know?
If you haven't done so already I highly recommend reading the docs for Grid Layouts to get a full understanding it works.
The Banner Headline uses the textstring grid editor, to see how the inline styling is generated for this look here.
Specifically for the Fanoe Starterkit the custom editors are defined in /App_Plugins/Grid/Config/FanoeConfig.txt and you'll find the Banner Headline there:
Changing automaticlly added style for H1
Hello.
This is what the rendered H1 looks like:
I would like to remove the style attribute and its styling so I can have my Banner headline responsive and changing size depending on device.
Help please!
KR, Mikael
Hi Mikael
/App_Plugins/Grid/Config/FanoeConfig.txtand you'll find the Banner Headline there:Style controls the backoffice rendering and markup how the value is wrapped on the frontend. Edit that to suit your needs and you should be golden :)
Hope that helps!
All the best
Rune
Found it and updated it but changing the file did not do it so I guess i have to rebuild something to make it work?
