  • Dmitriy 168 posts 588 karma points
    Sep 18, 2017 @ 15:36
    Dmitriy
    RTE styles does't work in views
    I created a custom styles to RTE, connected it to RTE and It works in the backoffice, but does't works with views (wraps text in tags, but don't apply styles).
    So, obviosly view does't reach the RTE.css.
    What should I do with that? Just link a RTE.css to my layouts or page? Or I dont know something about RTE result render?
  • Alex Skrypnyk 6182 posts 24283 karma points MVP 8x admin c-trib
    Sep 18, 2017 @ 15:37
    Alex Skrypnyk
    Hi Dmitriy,
    Just link a RTE.css to my layouts or page and be sure that your classes have the highest priority in CSS.
    Alex
    Sep 19, 2017 @ 08:36
    Dmitriy
    Hi, Alex.
    Very simple, as I thought :)
    Sep 25, 2017 @ 10:47
    Dmitriy
    To people with the same problem: Don't forget to add your RTE-styles to your bundles if you use it.
