Morning,
I'm running Umbraco 7.5.3 on Azure with an 1 admin server and 2 instances of public facing server.
Whenever I update content through CMS the content is replicated on the public facing servers.
Whenever a change is made to a template or RSS feed structure it doesn't update immediately.
I'm sure there is some stupid reason why this happens.. Can anyone point me in the right direction?
Andy
Hi Andy,
When you say it doesn't update immediately.. how long is it taking before it does actually show up? Or does it require user-interaction?
Also, are you using CachedPartial views by any chance?
Craig
Thanks for your reply Craig,
Unfortunately it doesn't update - and requires some manual intervention.. last time logging into the web app solved the problem...
Don't know if we're using CachedPartial views - how would I find this out? We're using Partial Views - and Redis Cache on Azure...
Thanks Andy
Hi Andy. How could you implement Azure Redis cache? Do you have some code? thanks
Umbraco 7.5.3 on Azure - Template Sync problem
Morning,
Andy
Hi Andy,
Craig
Thanks Andy
