  • Rob 22 posts 133 karma points
    Sep 19, 2017 @ 17:58
    Rob
    Filtering or Ordering by contents of radio buttons.
    Hi I am using umbraco 7.6
    I would like to know if it is possible to simply get a high number from a query on items that have a radio list.
    So for example
    I would like the highest number possible for say Bedrooms in a house.
    I have a data type bedroomNum which is a radio list with the numbers 1 to 10
    in a pagetype called houseDetail.
    Before I create a picker for max bedrooms I would like to only present what is possible.
    So the value I am looking for, for a variable is
    select the highest value of bedroomNum from all houseDetails How would
    I create a query for this if it is possible within a partial view.
    Kind Regards
    Rob
