  • Jason Batson 1 post 81 karma points
    Oct 03, 2017 @ 04:41
    Jason Batson
    How to disable caching for a particular Macro Partial
    Hey all,
    I have built some Umbraco Macro Partials and one of them displays dynamic data that shouldn’t be cached.
    Is there a way to disable cache for just this one Macro Partials?
  • Alex Skrypnyk 6176 posts 24187 karma points MVP 8x admin c-trib
    Oct 04, 2017 @ 09:21
    Alex Skrypnyk
    Hi Jason
    How did you make caching in your site?
    If you go to macro settings in the development section of Umbraco backoffice and go to the macro you need, you can set caching or cancel caching for each macro.
    Alex
