  • Martin 278 posts 662 karma points
    Oct 12, 2017 @ 10:42
    Martin
    Media Picker 2 - Umbraco 7.7 - 'System.Array' does not contain a definition for 'Url'
    Hi All,
    I'm having an issue showing an icon on the multi level navigation.
    I have a property on the document type - "navigationIcon" - which uses the Media Picker 2. I had it working previously on Media Picker 1 with the following code. I understand that Media Picker 2 using the UDI, but Im struggling to get it to work recursively.
    The error message I get is - 'System.Array' does not contain a definition for 'Url'
    Any help would be appreciated.
    Martin
    @foreach (var level2 in childPage.Children.Where("Visible")) {
    <li>
            <a class="cd-nav-item" href="@level2.Url" style="background-image:url('@level2.navigationIcon.Url')">
                <div class="title">@level2.Name</div>
            </a>
    </li>
    Oct 12, 2017 @ 11:33
    Alex Skrypnyk
    Hi Martin
    It looks like on your media picker enabled multiple medias, please check, just turn off multiple choice.
    If you need the possibility to select multiple media, try to use this code:
    @foreach (var level2 in childPage.Children.Where(x => x.IsVisible()))
        var imagesList = level2.GetPropertyValue<IEnumerable<IPublishedContent>>("navigationIcon");
        <li>
            <a class="cd-nav-item" href="@level2.Url" style="background-image:url('@imagesList.FirstOrDefault().Url')">
            </a>
        </li>
    Read more - https://our.umbraco.org/documentation/getting-started/backoffice/property-editors/built-in-property-editors/Media-Picker2
    Alex
