I see the site is running a recent verison of Umbraco - is the pagination all controlled via a razor partial view or is the functionality managed via a controller, ie compiled code.
In any case you'll need to provide some code in the forum for someone to truly be able to assist.
Without some code it is tricky to assist you, but nonetheless make sure that somewhere in your code you are setting the value of the page from the query string as that appears to be the problem. Make sure something like the following is being used:
int page;
int.TryParse(Request.QueryString["page"], out page);
Also ensure when fetching content nodes to skip/take based upon the above page and how many results per page.
HELP with Pagination please
On this page - https://www.arcticcabins.co.uk/latest-news-and-information/ - The numbers at the bottom of the page don't work properly, Can anyone help me with this please?
Hi Jon
Cheers, Nigel
Hi Jon
