Is it possible to combine the results of two multinode-treepickers and put them into a string?
I have a foreach statement to show some page results, which works but in certain cases I need to filter the results down further.
I have two variables which gets the selected filter and then a foreach statement with the results, inside here there are two multinode-treepickers and I need to set and if statement to match the string of the multinode-treepickers and the variables.
But I'm not sure if it's possible to bring the two multinode-treepicker results into a string.
Are you using Umbraco 7.6+? If so, MultiNodeTreePicker returns IEnumerable<IPublishedContent>
You can use the Union method to create a union of the results like so:
var mntp1 = Model.Content.GetPropertyValue<IEnumerable<IPublishedContent>>("mntp1");
var mntp2 = Model.Content.GetPropertyValue<IEnumerable<IPublishedContent>>("mntp2");
var union = mntp1.Union(mntp2);
If you just want the string of names:
var names = String.Join(", ", union.Select(m => m.Name));
Yes I'm using Umbraco 7.6.6, so I've used IEnumerable<IPublishedContent>
This is my foreach:
@foreach(var test in SearchResults.Skip((page-1)*numPerPage).Take(numPerPage)){
var thenode = Umbraco.Content(test.Id);
var keepcats = thenode.GetPropertyValue<IEnumerable<IPublishedContent>>("keepAChild");
var testlocs = thenode.GetPropertyValue<IEnumerable<IPublishedContent>>("locations");
if(!String.IsNullOrWhiteSpace(@keepKey) && !String.IsNullOrWhiteSpace(@countryKey)){ // Has country & keep a child searched
foreach(var keepitem in keepcats){
foreach(var locitem in testlocs){
if(keepitem.Name == @keepKey && locitem.Name == @countryKey){
<p>@thenode.Name | <b>@keepitem.Name</b> | <b>@locitem.Name</b></p>
if(keepitem.Name == @keepKey && locitem.Name != @countryKey){
<p>@thenode.Name | <b>@keepitem.Name</b> | @locitem.Name</p>
if(locitem.Name == @countryKey && keepitem.Name != @keepKey){
<p>@thenode.Name | @keepitem.Name | <b>@locitem.Name</b></p>
I've just tried using Union but I get this error:
CS1977: Cannot use a lambda expression as an argument to a dynamically dispatched operation without first casting it to a delegate or expression tree type
Combine two multinode-treepickers
Hi All,
Thanks!
Hi Lucy,
Do you have a sample of your code?
IEnumerable<IPublishedContent>You can use the Union method to create a union of the results like so:
Hi Matt,
IEnumerable<IPublishedContent>This is my foreach:
