I want all my Rich Text Editors to be surrounded by a border. I see that an empty div below the column div is created surrounding it, but I can't locate it to modify its class an apply my style. Here is an snippet of my code:
<div class="col-md-3 column">
<div> <!-- div which style I want to modify -->
<h2>Help<h2>
<p>Visit our guidance for tips and support, here.</p>
<h2>Favorite Functionalities</h2>
<ul>
<li>Meeting point</li>
<li>Our Corner</li>
<li>Documents</li>
</ul>
Do you mean the RTE in the CMS (backend) OR are you referring to the when you output the content of the RTE on the Frontend in your Views/Partials etc?
Apply stiles outside RTE
Hi All,
Any ideas?
Hi Francisco,
Is this the grid editor rte? If so, you can find the view file at
~Views/Partials/Grid/Editors/Rte.cshtmlIf it's on a page template however, you'll need to show us the full code, or at least where the RTE is getting rendered.
Hope that helps :)
Hi Ben, I didn't see you reply. This is what I wanted.
Thanks to both for your help
Hi Francisco,
Can you clarify what you mean a bit more...
Craig
Thanks for your answer Craig. I meant the RTE in the CMS.
