var max = CurrentPage.Parent.Children.Where("Visible");
foreach (var relatedItems in CurrentPage.Parent.Children.Where("Visible").Random(3))
<h4>@relatedItems.Id => @relatedItems.Name</h4>
I tried;
if (relatedItems.Name != Model.Content.Name)
Its works, but sometimes its only display two articles. I think the third article is hidden because of the if statement.
I'm stuck with this, any help would be appreciated!
How to show related articles?
I want to display a random related articles inside the articles page. Everything works well, but I want to exclude also the
CurrentPage.For example: I'm in the
Articles 1 Pageand I want to display only theArticles 2, Articles 3 & Articles 4But in my case, the
Articles 1is also shown.The Website structure.
Here's my code;
I tried;
two articles. I think the third article is hidden because of theif statement.I'm stuck with this, any help would be appreciated!
Hey Jin,
You could simplify this with the use of
.Siblingsfor example:Check out https://our.umbraco.org/projects/developer-tools/umbraco-v6-mvc-razor-cheatsheets for some more tips. It says v6 but is still relevant.
Hi Matt,
Thanks for your response.
But it keeps displaying the
Article 1 page.My question is
while I'm in the Article 1 pageI don't want thearticle 1shows in theRelated ArticlesProblem;
the article 1 is showing in the Related Articles.Hope I explain well :(
Regards,
Jin
Hi Matt,
Its working now, thanks to you :)
Alongside Siblings, you should really use an ID to compare rather than a name. You can do it in a lambda clause like so.
Model.Content.Sibings().Where(x => x.Id != Model.Content.Id)If you're using Models Builder you can even typecast to ensure it's only Articles you get
Model.Content.Siblings<Article>()...Hi Daniel,
It's working now :)
Thanks for your help!
