  • blackhawk 313 posts 1368 karma points
    Dec 01, 2017 @ 23:54
    blackhawk
    How to render a 2nd level for MegaNav with Models Builder
    The following code works for me in rendering a single level mega menu with Models Builder...
            if (Model.HasValue("MytopNav"))
                <ul>
                    @foreach (var item in Model.MytopNav)
                        <li class="dropdown">
                        @item.Title
                          @*check for child links here*@
                        </li>
                </ul>
    But if any of my parent level li's have child links, how do I check for that and add it to this logic?
  • Ben Palmer 180 posts 866 karma points c-trib
    Dec 02, 2017 @ 09:29
    Ben Palmer
    Hi blackhawk,
    You can just check for children in each loop and then do another loop inside, something like this:
        if (Model.Content.HasValue("MytopNav"))
            <ul>
                @foreach (var item in Model.MyTopNav)
                        @item.Title
                        @if (item.Children.Any())
                            <ul>
                                @foreach (var child in item.Children)
                                    <li>@child.Title</li>
                            </ul>
                    </li>
            </ul>
    Dec 02, 2017 @ 13:04
    blackhawk
    Thanks for the help! I only had to change Children() to Children.
    Dec 02, 2017 @ 16:20
    Ben Palmer
    Ah, so close! I had thought it was that actually but my Visual Studio told me otherwise. Strange, updated my answer to match however.
  • ibrahim TUNC 55 posts 133 karma points
    Feb 22, 2018 @ 17:13
    ibrahim TUNC
    How to render third and fourth levels for MegaNav with Models Builder?
