This is Umbraco version 7.7.4.
When I disable property value converters, I expect it to give me raw integer IDs, but instead I still get a list of IPublishedContent back. This is on both the new media picker and the new multi node picker.
Hi Brad
How did you disable propertyValueConverters?
Did you rebuild ModelsBulder's models?
Alex
I changed
I haven't done anything with the modelbuilders (but that is disabled as well via Umbraco.ModelsBuilder.Enable = false in web.config)
EnablePropertyValueConverters = false not working
Hi Brad
Alex
I changed
