  • blackhawk 313 posts 1368 karma points
    Dec 11, 2017 @ 16:34
    blackhawk
    how to properly render tags
    I'm on Umbraco 7.7.2 with Models Builder enabled. I created keywords for a page based on Umbraco Tags. I would like to render these tag values out to page. On one of my child templates, I have the following logic...
         @inherits Umbraco.Web.Mvc.UmbracoViewPage<ContentModels.FFacol1>
         @using ContentModels = Umbraco.Web.PublishedContentModels;
                Layout = "Master.cshtml";
        @section Keywords {
            var mkeywords = Model.Keywords;
               foreach (var item in @mkeywords) {
               @item
    ...But when I look at my page, it shows all my values compacted together like this....
    <meta name="keywords" content="value1value2value3value4etc..."
    How can I get proper spacing and commas in between each value?
  • Kevin Jump 2348 posts 14896 karma points MVP 9x c-trib
    Dec 11, 2017 @ 16:58
    Kevin Jump
    you can replace the loop with a string.Join command
    @string.Join(", ", Model.keywords)
    this should output something like,
    "Value1, Value2, Value3, ....."
    Dec 11, 2017 @ 17:11
    blackhawk
    Wow that is super short compared to a foreach loop! It works for me. Thanks!
