Hey,
Can some one tell mig what it is iam getting wrong in this macro.
I get this error on the page "Error reading XSLT file: Udtag.xsltUdtag.xslt
what is it iam trying to get it to do is act lig on this page.. http://solutionstomassconfusion.dk that is the HTML version off what aim trying to do.
Systeminformation:
Umbraco version 7.7.7 assembly: 1.0.6554.23584
this is my setup in the template
@section udtagelser{ <!-- section start --> <!-- ================ --> <div class="testimonial"> <div class="container"> <div class="row"> @Umbraco.RenderMacro("UdtagelseSlider", new {nodeId="umb://document/3745d7ef386742dcad6393691767100f"}) </div> </div> </div> <!-- section end --> }
This is my macro.
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:Examine="urn:Examine" exclude-result-prefixes="msxml umbraco.library Examine "> <xsl:output method="xml" omit-xml-declaration="yes" /> <xsl:param name="currentPage"/> <!-- Don't change this, but add a 'contentPicker' element to --> <!-- your macro with an alias named 'source' --> <xsl:variable name="source" select="/macro/source"/> <xsl:template match="/"> <!-- The fun starts here --> <ul> <xsl:for-each select="umbraco.library:GetXmlNodeById($source)/* [@isDoc and string(umbracoNaviHide) != '1']"> <li> <div class="col-md-8 col-md-offset-2"> <h2 class="title"><xsl:value-of select="UdtagelseOoverskrift"/></h2> <div class="testimonial-image"> <img src="images/testimonial-3.jpg" alt="Jane Doe" title="Jane Doe" class="img-circle"> </div> <div class="testimonial-body"> <p><xsl:value-of select="UdtagelseUdtagelsen"/></p> <div class="testimonial-info-1">- <xsl:value-of select="udtagelseUdtaler"/></div> <div class="testimonial-info-2"><xsl:value-of select="udtagelsePrivatFirma"/></div> </div> </div> </li> </xsl:for-each> </ul> </xsl:template> </xsl:stylesheet>
Coment macro problem
Hey,
Systeminformation:
This is my macro.
