Hi Team,
After I installed Full Text Search package in my Umbraco solution, site is throwing NullReferenceException. I set my site under default site folder in IIS. Kindly suggest solution for this.
Thanks in advance,
Suma
Hi Suma
Can you show all error message? Is there something in the log?
Did you set right Umbraco folders settings?
Should be like described here:
https://our.umbraco.org/documentation/getting-started/setup/install/permissions
/Oleksandr
Hi Alex,
Thanks for your reply.
Please find below the error message I am getting.
Hi Suma,
Have you updated the ExamineSettings.config and the ExamineIndex.config?
Please ensure there are no typo's etc. and you have followed the Documentation in regards to setup.
Let me know how it goes.
Craig
Hi Craig,
Thanks for the reply.
I updated both config files.
The same solution is working perfectly under main site folder in IIS. The issue is when I create it under default site only.
Umbraco site not working under default site in IIS
Hi Team,
Thanks in advance,
Suma
Hi Suma
/Oleksandr
Hi Alex,
Hi Suma,
Craig
Hi Craig,
Suma
