  • encoredatas 4 posts 73 karma points
    Jan 25, 2018 @ 15:42
    encoredatas
    Macro and Partial Views rendering deleted content.
    Hello Experts,
    I'm new to Umbraco , but not to developing. I'm noticing an issue in Umbraco with deleted content. A client of mine has deleted an event in the BackOffice , but the macro I created still pulls in and renders the deleted content. I have emptied the recyle bin but still shows up. I thought Umbraco only shows published content. Therefore, I'm puzzled why it can still be published. Here is the code in my macro. Thanks in advance!!
    @using ContentModels = Umbraco.Web.PublishedContentModels;
    @using Umbraco.Web;
        var homePage = CurrentPage.AncestorsOrSelf(1).First();
        var Events = homePage.eventOverview.First();
        var EventItems = Events.eventItem.OrderBy("eventDate");
        var sectionTitle = Model.MacroParameters["sectionTitle"] != null ? Model.MacroParameters["sectionTitle"] : String.Empty;
    @if (EventItems.Any())
        <!--Sidebar Page-->
        <div class="sidebar-page">
            <div class="auto-container">
                <div class="row clearfix">
                    <!--Content Side-->
                        <section class="four-column current-projects">
                                <div class="sec-title clearfix">
                                    <h2 class="skew-lines">DCAC <strong>Events</strong></h2>
                                    @foreach (var eventItem in EventItems)
                <!--Event List -->
                                        if (Umbraco.GetPreValueAsString(eventItem.eventType) == "DCAC")
                                            <div class="col-md-3 col-sm-6 col-xs-12 column project-column wow fadeInLeft" data-wow-delay="0ms" data-wow-duration="1000ms" style="min-height:450px !important;">
                                                <article class="column-inner hvr-float-shadow">
                                                    <figure class="image-box">
                                                        <a href="@eventItem.Url" target="_self">
                                                            <img src="@Umbraco.Media(eventItem.eventImage.ToString()).GetCropUrl("Medium")" />
                                                        </a>
                                                        <div class="icon-box">
                                            `            </div>
                                                    </figure>
                                                    <div class="lower-part">
                                                        <div class="text">
                                                            <h3>@eventItem.Name</h3>
                                                            <h5><b>Date and Time:</b></h5><p>@eventItem.eventDate.ToString("MM/dd/yyyy h:mm tt")</p>
                                                            <p>@eventItem.eventDescription</p>
                                                </article>
                        </section>
                    <!--Content Side-->
  • Alex Skrypnyk 6182 posts 24283 karma points MVP 8x admin c-trib
    Jan 25, 2018 @ 15:48
    Alex Skrypnyk
    Try to republish all site and nodes that you are using
    Also, please check is there some cache in your solution?
    Alex
    Jan 25, 2018 @ 15:50
    Nik
    Hi encoredatas,
    Following on from Alex's comment. Have you checked your macro settings? There is an option on macro's to enable caching which could be causing the issue you are seeing.
    If caching isn't enabled on the Macro, how are you calling the macro in the first place?
    Nik
    Jan 25, 2018 @ 15:52
    encoredatas
    2
    Thanks. It worked republishing the whole site. Nik to answer your question, I made sure the cache options where off. You guys are cool and nice. Thanks!
    Jan 25, 2018 @ 15:53
    Alex Skrypnyk
    You are welcome, have a great day!
