  • jools 15 posts 79 karma points
    Jan 29, 2018 @ 09:34
    jools
    Display number of Children for a specific name Node
    Im using this code to display the number of children underneath a specific node. At the moment it is doing so via the node's ID. Is there a way to set it so it goes off the Node's Name instead?
    code:
    var MYnode = Umbraco.TypedContent(1562); var MYchildAmount = MYnode.Children.Count();
    Currently @MYchildAmount jobs
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Jan 29, 2018 @ 12:12
    Steve Morgan
    Hi Jools,
    Something like should work - you get the website root node and then work down from there:
    var siteNode = Umbraco.TypedContentAtRoot().First();
    var locationsNode = siteNode.Children.Where(x => x.Name == "Locations").FirstOrDefault();
    var jobs = locationsNode.Children.Where(x => x.DocumentTypeAlias == "job").Count();
    I'm guessing jobs are in a location (this might be department or whatever so change this to suit). The last like counts the jobs - if you only have jobs under these containers you could remove the where check on the docType.
    This is a simple example that does no null checking. You probably should check if the locations node exists on the count.
        var jobs = locationsNode != null ? locationsNode.Children.Where(x => x.DocumentTypeAlias == "propertyArea").Count() : 0;
    Jan 29, 2018 @ 15:22
    jools
    Thanks Steve - that works great.
    Im just trying to develop it further using a loop, but being a designer my razor is very limited.
    <div class="box">
         <h2>IT Jobs</h2>
         <div class="job-info">
              <div class="count">There are currently @ITchildAmount jobs</div>
              <a href="/it-jobs/">View jobs</a>
         <div>
         <p class="no-jobs">Sorry no jobs available</p>
    <div>
    So all i want to do, is if the @ITchildAmount = 0 then hide the 'job-info' div and show the 'no-jobs' div instead.
    Trying to get a for loop going but doing something wrong.
    Might you be able to point me in the right direction?
    Thanks again
    Jan 29, 2018 @ 16:14
    jools
    Actually scratch that I’ve cracked it and got it working :)
    Jan 29, 2018 @ 18:17
    Steve Morgan
    Good job - glad you sorted it!
