  • Bent Holz 100 posts 273 karma points
    Feb 07, 2018 @ 10:35
    Bent Holz
    Problem with showing date from date picker
    I'm trying to create a very simple list of articles. On my doctype I have a property called "articleDate" with a Date editor set to mandatory.
    My partial view looks like this:
    @{ var selection = Model.Content.Children.Where(x => x.IsVisible()).ToArray(); }
    @if (selection.Length > 0)
            <ul>
                @foreach (var item in selection)
                    <li>
                        <a href="@item.Url">@Umbraco.Field("articleDate", formatAsDate: true) - @item.Name</a>
                    </li>
            </ul>
    But for some reason when outputting the list it replaces "articleDate" with the current date?!?... Am I doing something wrong and if yes.... what?
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Feb 08, 2018 @ 10:18
    Dave Woestenborghs
    Hi Bent,
    You can also do this
    @item.GetPropertyValue<DateTime>("articleDate").ToString("dd/MM/yyyy")
    Of course you need to change the format in the ToString to your desired format
    Dave
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Feb 08, 2018 @ 10:21
    Steve Morgan
    101
    Hi Bent,
    You're using @Umbraco.Field which will attempt to get the data from the current page node not the children so you want to use the item!
    You want something like:
    And you can control the format (I think you're in the US?) via something
    like:
    @(item<DateTime>("articleDate").ToString("MMM yyyy ddd d HH:mm"))
    Once your razor to format starts looking this complicated it's probably worth breaking it out a bit. So something like:
            <ul>
                    var formatedArticleDate = item.GetPropertyValue<DateTime>("articleDate").ToString("MMM yyyy ddd d HH:mm");
                    <li>
                        <a href="@item.Url">@formatedArticleDate - @item.Name</a>
                    </li>
            </ul>
    HTH
    Steve
    EDIT: Dave is much faster at typing than me
    Feb 08, 2018 @ 10:22
    Dave Woestenborghs
    2
    Probably because my answer is way shorter and not explaining why his approach didn't work :-)
    Dave
    Feb 08, 2018 @ 10:49
    Bent Holz
    Of course... And very nice answer :)
    Cheers!
