Could not task for operation Create for node type xslt
I've installed Umbraco version 7.8.1 from scratch.
Open Developer section
Click on "..." near XSLT files, get create XSLT fpom.
Enter new name ("asd", but get same result with any name)
Choose "Clean" snippet (reproduce with all other snippets in fact), uncheck "Create macro". Click "Create"
Always get an error
======== >8 ===============
Exception Details: System.InvalidOperationException: Could not task for operation Create for node type xslt
Source Error:
Stack Trace:
[InvalidOperationException: Could not task for operation Create for node type xslt]
Umbraco.Web.UI.LegacyDialogHandler.Create(HttpContextBase httpContext, User umbracoUser, String nodeType, Int32 nodeId, String text, Int32 typeId) +285
umbraco.presentation.create.xslt.sbmt_Click(Object sender, EventArgs e) +391
System.Web.UI.WebControls.Button.OnClick(EventArgs e) +11764877
System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +150
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1665
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.7.2558.0
XSLT file not created on a disk, When I refresh Developer section, there will be no XSLT files. If I check "Create macro", I get same error and macro is not created.
I can add XSLT file manually to XSLT folder on a disk, In this case I'll see XSLT in Developer section of Umbraco admin, can edit it, can save and can create macro. The problem is onmy with creating new file from admin UI.
I'm having the same problem with a fresh 7.9.2 install
Hi Guys,
I created a PR to fix this issue. To solve this just look at the steps in the comments of this issue : http://issues.umbraco.org/issue/U4-11149
Dae
