  • pbl_dk 150 posts 551 karma points
    Mar 12, 2018 @ 17:14
    pbl_dk
    ImageCropper error with macro and partial view
    Hi Forum. I am totally lost. I have tried hundreds of different things. I can not get any output with ImageCropper and Content in a Partial View.
    I have the code:
     var selection = Umbraco.Content(1086).Children().OrderBy("CreateDate desc");
     var numbers = 0;
    @foreach (var item in selection)
     if (item.HasValue("newsImage")) {
     <img src="@Url.GetCropUrl(item, propertyAlias: "newsImage", "newsPicture")" />
    Visual Studio just returns:
    'UrlHelper' has no applicable method named 'GetCropUrl' but appears to have an extension method by that name.
    Extension methods cannot be dynamically dispatched. Consider casting the dynamic arguments or calling the extension method without the extension method syntax.
    How can I get it to work?
    Mar 12, 2018 @ 17:17
    Alex Skrypnyk
    Hi Elitenet
    Use this code:
        var selection = Umbraco.TypedContent(1086).Children().OrderByDescending(x => x.CreateDate);
        var numbers = 0;
            <img src="@Url.GetCropUrl(item, "newsImage", "newsPicture")" />
    Mar 12, 2018 @ 17:18
    Alex Skrypnyk
    The problem is that you are using dynamics, use strongly types instead
    Mar 12, 2018 @ 17:33
    pbl_dk
    Thanks Alex!
    Just what I needed.
