  • Michael Jensen 29 posts 98 karma points
    May 11, 2018 @ 09:03
    Michael Jensen
    Image Slider Macro problem
    Hey,
    im making a new weebpaker for a body off live using Umbraco version 7.10.2 and for som reason I can't get my head around why my macro dont work.
    This is how it looks
    @inherits umbraco.MacroEngines.DynamicNodeContext
    @{ var startNodeID = Parameter.nodeId; }
    @if (startNodeID != null) {
    @* Get the start node as a dynamic node *@ var startNode = Library.NodeById(startNodeID);
    if (startNode.Children.Where("Visible") .Any())
        <ul>
            @foreach (var page in startNode.Children.Where("Visible"))
                <li onHoverStop: 'on' data-transition="@page.data-transition" data-slotamount="@page.data-slotamount" data-masterspeed=" @page.data-masterspeed" data-saveperformance="@page.data-saveperformance" data-title="@page.data-title">
                                <!-- LAYER Headline -->
                                <div class="tp-caption SliderTekstHeadline sfr tp-resizeme"
                                    data-x="0"
                                    data-y="70"
                                    data-speed="600"
                                    data-start="1200"
                                    data-end="9400"
                                    data-endspeed="600">@page.slideHeadline
                                <!-- LAYER Textline 1 -->
                                <div class="tp-caption sfb SliderTekst tp-resizeme"
                                    data-x="0"
                                    data-y="140"
                                    data-speed="600"
                                    data-start="1600"
                                    data-end="9400"
                                    data-endspeed="600">@page.slideTekst1
                                <!-- LAYER Textline 2 -->
                                    data-x="0"
                                    data-y="190"
                                    data-speed="600"
                                    data-start="2000"
                                    data-end="9400"
                                    data-endspeed="600">@page.slideTekst2
                                <!-- LAYER Textline 3 -->
                                <div class="tp-caption SliderTekst sfb tp-resizeme"
                                    data-x="0"
                                    data-y="240"
                                    data-speed="600"
                                    data-start="2400"
                                    data-end="9400"
                                    data-endspeed="600">@page.slideTekst3
                                <!-- LAYER Textline 4 -->
                                    data-x="0"
                                    data-y="290"
                                    data-speed="600"
                                    data-start="3200"
                                    data-end="9400"
                                    data-endspeed="600">@page.slideTekst4
                                <!-- LAYER Textline 5 -->
                                    data-x="0"
                                    data-y="340"
                                    data-speed="600"
                                    data-start="3600"
                                    data-end="9400"
                                    data-endspeed="600">@page.slideTekst5
                                <!-- LAYER Textline 6 -->
                                    data-x="0"
                                    data-y="390"
                                    data-speed="600"
                                    data-start="4000"
                                    data-end="9400"
                                    data-endspeed="600">@page.slideTekst6
                                   <!-- LAYER Link -->
                                    data-x="0"
                                    data-y="440"
                                    data-speed="600"
                                    data-start="4000"
                                    data-end="9400"
                                    data-endspeed="600">@page.slideLink
                                <!-- LAYER Image -->
                                <div class="tp-caption sfr tp-resizeme SliderImage"
                                    data-x="570"
                                    data-y="center"
                                    data-speed="600"
                                    data-start="2200"
                                    data-end="9400"
                                    <img src="@page.image" class="SliderRadius" alt="@page.altText" />
                                </li>
        </ul>
    I hvae tryed to convert it to XSLT but my problem is I can get it to work and the problem is in this line
    I can't wrap my head around it to get it to work
    I hop som can help me
    Best regards Michael
    May 11, 2018 @ 09:08
    Alex Skrypnyk
    Hi Michael
    You are using old methods, header I would rewrite to:
        var startNodeID = Model.MacroParameters["nodeId"];
        var startNode = Umbraco.Content(startNodeID);
        if (startNode.Children.Where("Visible").Any())
            <ul>
    And it's not a strongly typed also, so not perfect.
    where you have a problem, code like that doesn't work:
    Are you sure you have "data-masterspeed" property alias? Maybe "dataMasterspeed?
    Alex
    May 11, 2018 @ 09:43
    Michael Jensen
    Hey Alex,
    Well you is right about the @page.data-masterspeed but I dint look at as I use the macro on a mother site ware it works 100 %. whit that error
    i made the chance you advice me to and now my page dont fail in loading but gifs this. Error loading MacroEngine script (file: ForsideSlider.cshtml)
    This is how it looks like now have I miss something
    @{ var startNodeID = Model.MacroParameters["nodeId"]; }
    @if (startNodeID != null) { @* Get the start node as a dynamic node *@ var startNode = Umbraco.Content(startNodeID);
        <ul>
                <li onHoverStop: 'on' data-transition="@page.dataTransition" data-slotamount="@page.dataSlotamount" data-masterspeed=" @page.dataMasterspeed" data-saveperformance="@page.dataSaveperformance" data-title="@page.dataTitle">
                                    data-x="0"
                                    data-y="70"
                                    data-speed="600"
                                    data-start="1200"
                                    data-end="9400"
                                    data-x="0"
                                    data-y="140"
                                    data-speed="600"
                                    data-start="1600"
                                    data-end="9400"
                                    data-x="0"
                                    data-y="190"
                                    data-speed="600"
                                    data-start="2000"
                                    data-end="9400"
                                    data-x="0"
                                    data-y="240"
                                    data-speed="600"
                                    data-start="2400"
                                    data-end="9400"
                                    data-x="0"
                                    data-y="290"
                                    data-speed="600"
                                    data-start="3200"
                                    data-end="9400"
                                    data-x="0"
                                    data-y="340"
                                    data-speed="600"
                                    data-start="3600"
                                    data-end="9400"
                                    data-x="0"
                                    data-y="390"
                                    data-speed="600"
                                    data-start="4000"
                                    data-end="9400"
                                   <!-- LAYER Link -->
                                    data-x="0"
                                    data-y="440"
                                    data-speed="600"
                                    data-start="4000"
                                    data-end="9400"
                                    data-x="570"
                                    data-y="center"
                                    data-speed="600"
                                    data-start="2200"
                                    data-end="9400"
                                </li>
        </ul>
    May 11, 2018 @ 09:45
    Alex Skrypnyk
    Try to wrap "onHoverStop: 'on'" into
    <li <text>onHoverStop: 'on'</text>
    May 11, 2018 @ 09:48
    Michael Jensen
    Nop dint work i even relived it.. you can se the site her. Levins
    May 11, 2018 @ 09:49
    Alex Skrypnyk
    Can you have a look at app_data/logs?
    May 11, 2018 @ 09:52
    Michael Jensen
    Yes this is the log
    2018-05-11 11:51:18,909 [P1452/D2/T83] WARN umbraco.macro - Error loading MacroEngine script (file: ForsideSlider.cshtml, Type: ''. Exception: System.InvalidCastException: Context Must Implement System.Web.WebPages.WebPage at umbraco.MacroEngines.RazorMacroEngine.CompileAndInstantiate(String virtualPath) at umbraco.MacroEngines.RazorMacroEngine.ExecuteRazor(MacroModel macro, INode currentPage) at umbraco.MacroEngines.RazorMacroEngine.Execute(MacroModel macro, INode currentPage) at umbraco.macro.loadMacroScript(MacroModel macro) at umbraco.macro.renderMacro(Hashtable pageElements, Int32 pageId)
    May 11, 2018 @ 10:10
    Michael Jensen
    Hey Alex,
    whit the help you provided I believe I have fix it now the XSLT works I believe this it how it looks. I shows up and runs it dos not restart bud I believe I just ned to twerk on som.
    will not show the code even if use a code tag
