Yes, there is some extra configuration + some extra code that you need to build into your project. Doing it on my website because I had the exact same issue. Need to find the code (it's Saturday...) and will post.
I'm wondering why it is so important for them that the characters are not encoded? I mean when they see the site it's going to show just fine as España isn't it?
I just checked a couple of danish sites we have done throughout the years where danish characters like æ,ø and å are also getting encoded. So far I have not heard that it should be a bad thing? In terms of indexing the site in search engines this should not matter either.
Jan: because the page looks ugly when you look at the source + every single char such as 'é' turns into 'Ӓ' ie 7 chars - I know bandwidth is cheap, but stil.
How do I display non-English characters eg. the Spanish ñ in Razor views without encoding them?
This might be an easy thing to fix.
I have a multi language site, the Spanish version of the site is set up to use the es-Es culture and the language is set as:
However, when any content is added in the CMS that contains special non-English characters, these are encoded when I checked the source:
There is a client requirement for these not to be encoded, when viewing source, it should be:
I know I can use Html.Raw() to not escape the characters, but this wouldn't work with other html entities like ampersand that need to be encoded.
Is there some extra configuration I need to do to change this?
Hi Matt
Aaah yes, I never thought of it in that context. But it makes sense #h5yr :-)
There: https://www.zpqrtbnk.net/posts/lightweight-page-content-encoding
Stephen, that is awesome, that is a great article and is exactly what I need. H5YR
