  • Thomas 319 posts 606 karma points c-trib
    Jun 01, 2018 @ 08:52
    Thomas
    Failed to load resources
    Anyone that have tried this? The issue just came out of the blue.
    Haven't touched the page for a while and then this happen. Look like to url where it looks for the files are wrong
    Umbracro error
    Jun 01, 2018 @ 09:45
    Thomas
    Could it be something with the rewrite rules?
    <rewrite>
      <rules>
          remove www from all requests and if not https then https it!
        <rule name="Remove www" patternSyntax="Wildcard" stopProcessing="true">
          <match url="*" />
          <conditions>
            <add input="{CACHE_URL}" pattern="*://www.*" />
          </conditions>
          <action type="Redirect" url="https://{C:2}" redirectType="Permanent" />
        </rule>
        <rule name="Redirect to http" enabled="true" patternSyntax="Wildcard" stopProcessing="true">
          <match url="*" negate="false" />
          <!-- do nothing if https://-->;
          <conditions logicalGrouping="MatchAny">
            <add input="{HTTPS}" pattern="off" />
          </conditions>
          <action type="Redirect" url="https://{HTTP_HOST}{REQUEST_URI}" redirectType="Found" />
        </rule>
          enforce https on http requests
      </rules>
    </rewrite>
    Jun 01, 2018 @ 10:35
    Thomas
    It's an Chrome issue..
    Jun 01, 2018 @ 14:21
    Dave Woestenborghs
    This is probably the chrome 66 update. This is issue is known and can be fixed by an upgrade.
    If you are not ready for an upgrade you can do some manual patching.
    See http://issues.umbraco.org/issue/U4-11253 for instructions.
    Dave
