I found it to be an excellent solution to overcome a strange limitation. It works fine for content ListViews.
Now I tried to extend it to cover member ListViews as well.
I find the member content. The items collection is iterated. The prop.Value is detected, translated and set with new display text value. BUT the displayed view still holds the id arrays: ["38"] and not the generated texts.
Why is that? Is there some hidden difference in how member list views are displayed compared to content list views? Is there a difference in event chain causing the updated values to be neglected?
I am really confused.
public class FixDropDownPreValueDisplayInListViewsHandler : DelegatingHandler
// Ensure we're only processing requests to getchildren - hopefully only listviews
private static readonly string[] PathsWithTranslationNeeds = { "/umbraco/backoffice/UmbracoApi/Content/GetChildren", "/umbraco/backoffice/UmbracoApi/Member/GetPagedResults" };
protected override async Task<HttpResponseMessage> SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
// Wait for the request to be processed
var response = await base.SendAsync(request, cancellationToken);
var absolutePath = request?.RequestUri?.AbsolutePath;
if (!absolutePath.IsNullOrWhiteSpace() && PathsWithTranslationNeeds.Contains(absolutePath))
var content = (ObjectContent)response.Content;
// Swap individual properties with text representation where appropriate
switch (content?.Value)
case PagedResult<ContentItemBasic<ContentPropertyBasic, IContent>> contentResult:
if (contentResult.Items != null)
foreach (var item in contentResult.Items)
if (item != null)
foreach (var prop in item.Properties.Where(p => DropListTranslator.IsTranslatedType(p.Editor)))
prop.Value = DropListTranslator.GetText(prop.Value);
break;
case PagedResult<MemberBasic> memberResult:
if (memberResult.Items != null)
foreach (var item in memberResult.Items)
if (item != null)
break;
return response;
DropDownList values displayed in content ListViews but not in member ListViews
I followed suggestions from here: https://gist.github.com/tompipe/beaf44f29d416249dfdeaa9d1b24956a
Now I tried to extend it to cover member ListViews as well. I find the member content. The items collection is iterated. The prop.Value is detected, translated and set with new display text value. BUT the displayed view still holds the id arrays: ["38"] and not the generated texts.
