  • Mário Nunes 7 posts 87 karma points
    Jul 15, 2018 @ 16:33
    Mário Nunes
    Is it possible to load a View without setting the Template for the Document Type?
    Weird question!
    Is it possible to load a view without setting the template on the document type?
    If the template is not set, it always goes to 404 page and never enters the controller.
    I'm doing this because I don't want that specific view on the backoffice.
    Thanks!
  • Rihab 104 posts 388 karma points
    Oct 28, 2019 @ 11:03
    Rihab
    Did you find a way yo do that? I'm facing the same problem
    Nov 08, 2019 @ 09:09
    Mário Nunes
    Hey, what I ended up doing was registering a controller at runtime, like this:
    RouteTable.Routes.MapRoute(
               "RouteName",
               "route",
               new { controller = "ControllerName", action = "ActionName" });
    Then on the controller:
     public ActionResult ActionName()
            BaseModel model = ... (here I just got my homepage IPublishedContent) since the model didn't matter, just needed it for the base layout;
            return View("~/path/to/view.cshtml", model);
    To note, I did all this on a different .csproj aside the main project, as an extensible plugin.
