  • Adriano Fabri 469 posts 1633 karma points
    Jul 26, 2018 @ 16:18
    Adriano Fabri
    [SOLVED] Best way to filter nodes by checking a checkBoxList
    Hi, I have a checkboxlist datatype that have three values.
    Now I need to filter nodes by checking inside this checkboxlist that must contains a specific value.
    Now I get the full list of nodes with this code
    var listNodes = CurrentPage.Descendants("article").Where("Visible").OrderBy("date descending");
    Each article have a checkBoxList (alias sectionList) that I must use to filter the listNodes.
    I think I can do something like this...
    var listNodes = CurrentPage.Descendants("article").Where("a => a.sectionList.Split(',').Contains('mySection')").Where("Visible").OrderBy("date descending");
    I tried many combinations but none worked.
    In most cases I received the error that I can not use the lambda.
    Any idea?
  • Dan Diplo 1554 posts 6205 karma points MVP 6x c-trib
    Jul 26, 2018 @ 18:56
    Dan Diplo
    I would use a strongly-typed query rather than dynamics. Something like:
    var listNodes = Model.Content.Descendants("article").
    Where(a => sectionList.Split(',').Contains("mySection")).
    Where(n => n.IsVisible()).OrderByDescending(n => n.CreateDate);
    Jul 26, 2018 @ 22:50
    Adriano Fabri
    Thank you Dan, tomorrow I'll test your solution.
    Have a good day Adriano
    Jul 27, 2018 @ 08:37
    Adriano Fabri
    Hi Dan,
    the query you gave me returned some errors, anyway starting from this I made some changes and the final code is:
        .Where(v => string.Join(",", v.GetPropertyValue<IEnumerable<string>>("sectionList")).Split(',').Contains("mySection"))
        .Where(n => n.IsVisible())
        .OrderByDescending(d => d.GetPropertyValue<string>("date"));
    Thank you for the support
    Adriano
    Jul 27, 2018 @ 09:45
    Dan Diplo
    No problem! I didn't realise that the sectionList was a property of the node which is probably why my version didn't work.
    I would definitely recommend using strongly-typed queries like this rather than using dynamics as these execute faster, you get better intellisense and they're going to be dropped in Umbraco 8.
