HI Guys,
I need some help/guidance here, I'm trying to upload files into Umbraco but not into the media folder but to the Azure storage Blub.
The issue: Files uploaded to Blob successfully but corrupted.
Note: Same files, blob storage, same upload function works in external project out side umbraco works fine !.!
private async Task<int> SaveCustomDetails(UserMember user, UserCustomViewModel model) { .. if (model.ProfessionalImage != null) { details.ProfessionalImage = await FilesManager.UploadAsync(model.ProfessionalImage, memberId); } } public static async Task<string> UploadAsync(HttpPostedFileBase fileToUpload, int memberId) { string fileFullPath = null; if (fileToUpload == null || fileToUpload.ContentLength == 0) { return null; } try { CloudStorageAccount cloudStorageAccount = CloudStorageAccount.Parse(ConfigurationManager.AppSettings["StorageAccountConnection"].ToString()); CloudBlobClient cloudBlobClient = cloudStorageAccount.CreateCloudBlobClient(); CloudBlobContainer cloudBlobContainer = cloudBlobClient.GetContainerReference(memberId.ToString()); await cloudBlobContainer.CreateIfNotExistsAsync(); await cloudBlobContainer.SetPermissionsAsync( new BlobContainerPermissions { PublicAccess = BlobContainerPublicAccessType.Blob } ); string fileName = fileToUpload.FileName; CloudBlockBlob cloudBlockBlob = cloudBlobContainer.GetBlockBlobReference(fileName); cloudBlockBlob.Properties.ContentType = fileToUpload.ContentType; await cloudBlockBlob.UploadFromStreamAsync(fileToUpload.InputStream); fileFullPath = cloudBlockBlob.Uri.ToString(); } catch (Exception ex) { } return fileFullPath; }
Upload image
Issue Uploading files to Azure storage blob size 0, from MVC pages surface controller
HI Guys,
