I need to create a page that is populated from an external SQL database. The query is as follows:
SELECT * FROM [dbo].[tvfn_TableName] (240, 1, 0)
What I need is to replace the first parameter (240) with Umbraco.Field("programKey"), but I can't make it work. Everything in my brain says the following should work:
This triggers an 'Application roles can only be activated at the ad hoc level.' error. If that parameter is hard-coded (e.g.240), everything runs just perfectly, but being a template page it will always load the data for that particular programKey.
Looking for any ideas/suggestions. I have been working with my data guy, but he's baffled too.
External SQL Queries
Thanks, Greg
