  • Rabea 34 posts 186 karma points
    Nov 26, 2018 @ 07:05
    Rabea
    Model mismatch error
    Hi, I am getting the following error when trying to add a partial view to a main view. The main view has a model generated by modelsbuilder and the partial view has an archetype model created by us. Is there a way to fix this?
    Cannot bind source type Namespace.Core.Models.Archetype Models.Text With Picture to model type Umbraco.Core.Models.IPublishedContent
    Nov 26, 2018 @ 10:41
    Nik
    Hi Rabea,
    How are you calling your partial view? And what does your partial view look like?
    Nik
    Nov 26, 2018 @ 10:54
    Rabea
    I am calling the partial view using a controller method as the model for partial view is different in different cases. Below is the code:
    MainView.cshtml:
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<MainView>
    //Call for dynamic partial view
     @Html.Partial("Sections", Model)
    Sections.cshtml:
    @foreach (var section in Model.Sections)
    {        if (!section.Disabled)
        {            @Html.Action("GetSection", "SectionSurface", new { model = section })   }  }
    Controller:
     public class SectionSurfaceController : SurfaceController
            [ChildActionOnly]
            public ActionResult GetSection(ArchetypeFieldsetModel model)
                SectionResolver resolver = new SectionResolver(model); //create instance of section resolver class
                return PartialView(resolver.ViewPath, resolver.Model); //render view with path from resolver and specific model
    Resolverhelper:
    public class SectionResolver
            private const string ViewsPathRoot = "~/Views/Partials/Sections/"; //default path to the sections views
            private const string ModelsNamespace = "Namespace.Core.Models.ArchetypeModels"; //default namespace for the sections models
            private string _name;
            private ArchetypeFieldsetModel _model;
            public SectionResolver(ArchetypeFieldsetModel model)
                _model = model;
                var name = model.Alias;
                if (string.IsNullOrWhiteSpace(name))
                    throw new ArgumentException("Name of section can`t be empty");
                _name = name.First().ToString().ToUpper() + name.Substring(1);
            public string Name
                get
                    return _name;
            public string ViewPath
                get
                    return ViewsPathRoot + _name + ".cshtml";
            public object Model
            {            get
                     Type modelType = Type.GetType(ModelsNamespace + "." + _name, false, true);
                    if (modelType == null)
                    {                    return null;                }
                    return Activator.CreateInstance(modelType, _model);
    PartialView:
        @inherits Umbraco.Web.Mvc.UmbracoViewPage<Namespace.Core.Models.ArchetypeModels.TextWithPicture>
    //Rest of Code for view
    Any idea? Thanks
