  • Jesper Skjønnemand 66 posts 441 karma points c-trib
    Dec 05, 2018 @ 11:50
    Jesper Skjønnemand
    merge noindex and nofollow
    In my master template I have this code
    @if (CurrentPage.seoIndex == true)
    {<meta name="robots" content="index">}
    else if (CurrentPage.seoIndex == false)
    {<meta name="robots" content="noindex">}
    @if (CurrentPage.seoFollow == true)
    {<meta name="robots" content="follow">}
    else if (CurrentPage.seoFollow == false)
    {<meta name="robots" content="nofollow">}
    It creates this
    which is nice, but this would be nicer
    <meta name="robots" content="noindex,nofollow">
    Any suggestions to achieve this?
    Best
    Dec 05, 2018 @ 20:51
    Hi Jesper
    One way of achieving it could be to do the following:
        string seoIndexValue = "noindex";
        string seoFollowValue = "nofollow";
        if(CurrentPage.seoIndex == true){
            seoIndexValue = "index";
        if(CurrentPage.seoFollow == true){
            seoFollowValue = "follow";
    <meta name="robots" content="@seoIndexValue, @seoFollowValue" />
    So by setting up 2 variables for holding the desired values it becomes a bit easier. By default we will set them to noindex and nofollow and then do 2 checkes on each of the settings on the currentpage and overwrite the initial value with the value we want when a setting is true.
    In the end we reference the variables in the content attribute separated by a comma.
    I hope this works for you - There are most likely other ways of doing this but this is what I could come up with from the top of my mind and it should work just fine :)
