  • Hayden Tomas 11 posts 82 karma points
    Jan 07, 2019 @ 23:44
    Hayden Tomas
    Media picker url output to template help!
    Hi guys,
    So I am an Umbraco newbie and practicing my templating. I want to create my own open graph section which will only display if the user chooses to fill in the data.
    So in my partial I have the following (I grabbed and modified the code from RankOne seo plugin)
        @if(Model.Content.HasProperty("ogImage") && Model.Content.HasValue("ogImage")){
    <meta property="og:image" content="@(Model.Content.GetPropertyValue<string>("ogImage"))"/>
    code example
    I have uploaded the image as i am not sure if the code shows correctly! But this outputs a code value, not the url of the image when using the media picker.
    What do i need to do in order to make umbraco output the uploaded image url onto my template?
    Thanks!
  • Richard Eyres 98 posts 580 karma points
    Jan 08, 2019 @ 07:45
    Richard Eyres
    I believe the image would be an iPublishedContent, so you could use the following:
