  • Jared 2 posts 72 karma points
    Feb 07, 2019 @ 13:11
    Jared
    Best way to add text/javascript block and iFrame to a site?
    Hi everyone,
    New to using Umbraco and would really appreciate some advice regarding embedding iFrames to a site.
    I have the following to add to the < head >
    < script> src="https://cezanneondemand.interweb.it/integration/announces_js.php?&h=400&w=800*lang=en&k=f9e0bec95db28fc=companyname&d=website&view=list" type="text/javascript"> < / script >
    Then this following to add to the < body >
    < div id-"inrecruiting_announces">< / div>
    inRecruiting("inrecruiting_announces").inrIframe{{
        bgColor:"FFFFFF",
        bgRowVacancy:"FDFDFD",
        SeparatoColor: "AAAAAA",
        filterColor: "494444",
        jobTitleActiveColor:"888888",
    Based on what I've researched so far I assume I need to add the < head > script in the relevant page template under settings, then create a partial view macro file for the body script to then reference as a macro. However I'm a bit lost in terms of how to format the partial view macro file or if there is a better way of doing it?
    Thanks in advance, if any further detail helps just let me know.
  • louisjrdev 107 posts 344 karma points c-trib
    Feb 07, 2019 @ 17:13
    louisjrdev
    I would create 2 fields on your doctypes both textareas, call one Head Scripts and one Body Scripts and then in your master template you can call each of them like so:
    <head>
        @Html.Raw(Model.Content.GetPropertyValue<string>("headScripts"))
    </head>
    <body>
        @Html.Raw(Model.Content.GetPropertyValue<string>("bodyScripts"))
    </body>
    you can then add your scripts (in html script tags) into these fields in the backoffice and they will display on the site (dont forget to null check)
    Feb 08, 2019 @ 09:03
    Jared
    Hi Louis,
    Thanks for your response, really appreciate it. I've added the script with the method you described, however upon previewing the changes I'm receiving the following error message where I expect to see the script result:
    "Warning: vacancy not found"
    Could you advise what could be causing that please?
    Screenshot
    Feb 08, 2019 @ 09:10
    louisjrdev
    looks unrelated, nothing with the code i specified would cause that error, assuming a normal umbraco setup
