  • Eli 15 posts 95 karma points
    Mar 30, 2019 @ 03:14
    Eli
    Get previous and next sibling from same type
    I am trying to implement "Next" and "Previous" buttons in a blog article page. For doing so I simply need to get the next/previous siblings of the current page (from the same type).
    Couldn't find a proper answer for this issue.
    Cheers
    Mar 31, 2019 @ 01:04
    Eli
    Can't believe I missed it.
    CurrentPage.Next()
    CurrentPage.Previous()
    But how can I check their type & visibility?
    Apr 01, 2019 @ 12:48
    Alex Skrypnyk
    Hi Eli,
    Mu much better to use these lines:
    var prev = Umbraco.AssignedContentItem.Previous();
    var next = Umbraco.AssignedContentItem.Next();
    How to check visibility and document type alias:
    var isVisible = prev.IsVisible();
    var documentTypeAlias = prev.DocumentTypeAlias;
    Alex
    Apr 02, 2019 @ 23:53
    Eli
    Thanks Alex, but I want to retrieve the next sibling that is visible from the same type, and not just get the next/previous one and check if they are visible and their type. Is there an short query for that or should I iterate over all of my siblings until I get one that fits me?
    Cheers
  • Bharti 8 posts 74 karma points
    Apr 01, 2019 @ 09:33
    Bharti
    Hi Eli,
    Try using:-
    Getting The Current Page Via The Database To get the content via the database, so you can write to it as well, you need to use a different API, like so:
    var currentPageId = UmbracoContext.Current.PageId;
    IContent content = ApplicationContext.Current.Services.ContentService.GetById(currentPageId);
    Apr 01, 2019 @ 12:50
    Alex Skrypnyk
    2
    Hi Bharti
    Never user "ContentService" for displaying content.
    "ContentService" is for making changes in the database. It's a heavy method, on the pages user IPublishedContent always!
    Have a look at "Common Pitfalls & Anti-Patterns" and never do it like that:
    https://our.umbraco.com/documentation/Reference/Common-Pitfalls/
    Alex
  • David Armitage 510 posts 2082 karma points
    Sep 22, 2023 @ 06:08
    David Armitage
    Hi All,
    Here is what I have done. Seems to do the trick.
    Obvs switch out my CaseStudyDetailsPage for IPublishedContent or whatever page type you are using.
    IEnumerable
    CaseStudyDetailsPage nextPage = null;
    CaseStudyDetailsPage previousPage = null;
    if(siblingCaseStudyPages != null && siblingCaseStudyPages.Count() >= 2)
        previousPage = siblingCaseStudyPages.LastOrDefault(x => x.SortOrder < caseStudyDetailsPage.SortOrder);
        nextPage = siblingCaseStudyPages.FirstOrDefault(x => x.SortOrder > caseStudyDetailsPage.SortOrder);
