  • Maneesh Kothari 3 posts 73 karma points
    Apr 16, 2019 @ 10:23
    Maneesh Kothari
    Solution to write XSLT
    I have below XML format.
    And I have to extract value from tag NAMENUM on the basis of delimiter(.) .I need a out after applied XSLT.
    <PNRNames>
        <PNRName>
            <PNR_ID>1125280434952240</PNR_ID>
            <NAMENUM>2</NAMENUM>
            <suffix>10<suffix>
            <prefix>2</prefix>
            <FIRSTNAME>JEFFREYBRIAN</FIRSTNAME>
            <LASTNAME>MINEAR</LASTNAME>
            <STATINFO/>
        </PNRName>
    </PNRNames>
    I am new in xslt.your help really appreciable
    Apr 16, 2019 @ 10:42
    Maneesh Kothari
    I find the solution .
    Apr 16, 2019 @ 10:51
    Hi Maneesh
    Great to see you found the solution to your issue/challenge.
    Could you perhaps share your solution in case others face the same challenge as you at some point? :-)
    Happy coding!
    Apr 23, 2019 @ 18:14
    Maneesh Kothari
    Use substring-after and before like below.
                     <xsl:value-of select="substring-after(NAMENUM,'.')"/>
                    </passengerNumber>
                    <prefix>
                     <xsl:value-of select="substring-before(NAMENUM,'.')"/>
                    </prefix>
                    <suffix>
                    </suffix>
