I would love to get some help to optimize my code.
I have 2 document types. Speaker and Session.
The Session documentype have among other properties a "Speakers" property, which is a multiple Treepicker.
In my Speaker template, I want to list all sessions that a speaker is in.
Currently I use this code, and it works, but it seems like bad performance to to through all sessions in a loop, and then another loop to check which sessions a speaker is in.
var selection = Umbraco.Content(Guid.Parse("fb14808c-7e8c-404c-9c07-af8e7b92622c")) // all sessions
.Children()
.Where(x => x.IsVisible());
foreach (var item in selection) // loop all sessions
var selection2 = item.Value<IEnumerable<IPublishedElement>>("speakers"); // all speakers in that session
if(selection2 != null) {
foreach (var session2 in selection2)
if(@session2.Value("pageTitle")==Model.Value("pageTitle")) { // write out if the speaker is in this sessions.
<li><a href="@item.Url">@item.Name</a></li>
As I understand it, you have a Speaker and a Session. Session has a list of speakers.
To get all the sessions that a speakers is in, could then be done with:
put this a the top of you view, before any of the html
// get all sessions as a list to avoid multiple iterations...
var allSessions = Umbraco.Content(Guid.Parse("fb14808c-7e8c-404c-9c07-af8e7b92622c"))
.Children()
.ToList();
// get sessions for a speaker
var speakerSessions = allSessions
.Where(x=>{
//select the speakers and check if the match the current speaker (model)
var speakers = x.Value<IEnumerable<IPublishedElement>>("speakers");
return speakers != null && speakers.Any(s=>s.ID=Model.ID)
.ToList();
put this in the body of the view, where needed
@foreach(var session in speakerSessions){
<li><a href="@session.Url">@session.Name</a></li>
I don't recommend you use the "pageTitle" as a way to match if the documents are the same.
CS1061: 'IPublishedElement' does not contain a definition for 'ID' and no accessible extension method 'ID' accepting a first argument of type 'IPublishedElement' could be found (are you missing a using directive or an assembly reference?)
I just copied your code, and did’nt see that you read the speakers as IPublishedElement, but it should be IPublishedContent.
.Where(x=>{
var speakers = x.Value<IEnumerable<IPublishedContent>>("speakers");
return speakers != null && speakers.Any(s=>s.ID==Model.ID)
}).ToList();
Need help to avoid loop in loop
Hi Søren
Thank you so much, this was exactly what I was looking for!
One small issue, not sure why I get this error But in
I get an error.
So right now I changed it to
But you are right, it would be much better with ID, but I just can't get it to work.
The top of my template looks like this
Hi Søren
Ohh, should have seen that myself :-)
You have been a great help, thank you so much.
Best regards
Jimmy
