Can i use model generated in AppData mode on another template
Can I use models in AppData mode generated by models builder in another Document Type template?
What i am trying to do:
I have node News and his child News Item , where i want to create and update news programmatically but from another templates called Create News and Update News.
I have tried to inherit News Item model in Create News and Update news templates like this:
I'm not sure if I understand what you are wanting to do. It sounds like you want to present a news story in one of three formats. In this case you would have 3 views(templates) for each NewsItem. If you are wanting the newsitem to display in one of three ways, then you will need a Property on your newsitem to allow your code to know which way to display the newsitem. A bit of psuedocode below. Assume that News is the parent Document Type and NewsItem is the child. Your news.cshtml file might look like:
@inherits Umbraco.Web.Mvc.UmbracoViewPage<ContentModels.News>
@using ContentModels = Umbraco.Web.PublishedModels;
//Partial view that can be palced on any skin.
Layout = null;
IPublishedContent theNews = GetNews();
<h1>News</h1>
@foreach(News itm in theNews)
switch(itm.NewsFormat)
case "Format1":
@Html.Partial("~/Views/Format1.cshtml", itm)
break;
case "Format2":
@Html.Partial("~/Views/Format2.cshtml", itm)
break;
case "Format3":
@Html.Partial("~/Views/Format3.cshtml", itm)
break;
default:
<div>No format Available for news</div>
break;
and like this:
But its not working. What would be the best way to do this?
Would it be good solution to create 3 templates from same document type maybe?
I dont know what is the best practice to do it.
What the above code does is basically leverages the power of MVC partial views so that your data is separate from how it is presented. I believe that the following link kind of explains a bit of pre-requisite knowledge:https://our.umbraco.com/documentation/Tutorials/Creating-Basic-Site/Articles-Parent-and-Article-Items/
