  • Bo Jacobsen 609 posts 2408 karma points
    May 21, 2019 @ 11:18
    Bo Jacobsen
    How to work with DI in .cshtml razor views
    Hi all.
    We are trying to migrate from Umbraco 7 to Umbraco 8. And in the process we learned about DI and IoC, and tried to convert it to DI. But we came across an issue we dunno how to handle correctly.
    Let's say, we have a layout .cshtml file for all our views. So the layout file do not have a controller assosiated and we wanna use an extension, that use code we already have in some services. What to do?
    @using {projectname}.CustomExtention
        Layout = null;
    <!DOCTYPE html>
    <html>
    <head>
        <meta charset="utf-8">
        <meta http-equiv="X-UA-Compatible" content="IE=edge">
        <meta name="viewport" content="width=device-width, initial-scale=1">
        <title>Umbraco Rocks!</title>
        @Html.CustomFunction(Model.Id)
    </head>
    <body>
        @RenderBody()
    </body>
    </html>
    We made an Extension for the HtmlHelper to render some scripts. Inside this extension we wanna be able to use 2 custom services.
    namespace {projectname}.CustomExtention
        public static class IPublishedContentExtension
            // IUmbracoHelperService
            // IHostingEnvironmentService
            public static MvcHtmlString CustomFunction(this HtmlHelper helper, int id)
                // Just for Fiction
                var content = UmbracoHelperService.TypedContent(id);
                var path = HostingEnvironmentService.MapPath(content.Url);
                return new MvcHtmlString(stylesheets);
    We already create IHostingEnvironmentService, HostingEnvironmentService, to use in some components and controllers, so we are able to use the logger.
    public interface IHostingEnvironmentService
        DirectoryInfo GetDirectory(string pathAndName);
    public class HostingEnvironmentService : IHostingEnvironmentService
        private readonly ILogger _logger;
        public HostingEnvironmentService(ILogger logger)
            _logger = logger;
        public string MapPath(string pathAndName, bool createIfNotExists = false)
            try
            catch (Exception ex)
                _logger.Error<HostingEnvironmentService>("Bla bla bla", ex);
    We also created IUmbracoHelperService, UmbracoHelperService. To use in some components and controllers, so we were able to use the IUmbracoContextFactory.
    public interface IUmbracoHelperService
        IPublishedContent TypedContent(int id);
    public class UmbracoHelperService : IUmbracoHelperService
        private readonly IUmbracoContextFactory _context;
        public UmbracoHelperService(IUmbracoContextFactory context)
            _context = context;
        public IPublishedContent TypedContent(int id)
            using (var cref = _context.EnsureUmbracoContext())
    We already install these in an IUserComposer
    public class Installer : IUserComposer
            composition.Register<IHostingEnvironmentService, HostingEnvironmentService>();
            composition.Register<IUmbracoHelperService, UmbracoHelperService>();
    But are we able to use it in our CustomExtention or what would be best practice?
  • Marc Goodson 2157 posts 14432 karma points MVP 9x c-trib
    May 23, 2019 @ 08:14
    Marc Goodson
    Hi Bo
    What I tend to do is create my own version of UmbracoViewPage
    There is some WIP documentation in progress here:
    https://github.com/umbraco/UmbracoDocs/compare/v8/ServicesPattern?short_path=cf2726d#diff-cf2726d2ea2b6f60e0225ce051876a55
    that has the following example of how to do this:
    using System;
    using System.Linq;
    using System.Web;
    using Umbraco.Core;
    using Umbraco.Core.Cache;
    using Umbraco.Core.Composing;
    using Umbraco.Core.Services;
    using Umbraco.Web.Mvc;
    using Umbraco8.Services;
    using Current = Umbraco.Web.Composing.Current;
    namespace Umbraco8.ViewPages
        public abstract class CustomViewPage<T> : UmbracoViewPage<T>
            public readonly ISiteService SiteService;
            public CustomViewPage() : this(
                Current.Factory.GetInstance<ISiteService>(),
                Current.Factory.GetInstance<ServiceContext>(),
                Current.Factory.GetInstance<AppCaches>()
            public CustomViewPage(ISiteService siteService, ServiceContext services, AppCaches appCaches)
                SiteService = siteService;
                Services = services;
                AppCaches = appCaches;
            protected override void InitializePage()
                base.InitializePage();
        public abstract class CustomViewPage : UmbracoViewPage
            public readonly ISiteService _siteService;
                _siteService = siteService;
    and then in your view
    @using Umbraco8.ViewPages
    @inherits CustomViewPage
        Layout = "master.cshtml";
        IPublishedContent newsSection = SiteService.GetNewsSection();
    <section class="section">
        <div class="container">
            <article>
    this might just be personal preference, but the outcome is that in the view there isn't anything 'getting' services etc - in current project I'm using this instead of the HtmlHelper ExtensionMethods... I'd used in V7.
    Anyway the key to it is anywhere you can get the current reference from a service that's registered with DI by using:
    (if you can't inject it via a constructor)
    Not sure if that answers your question though!
    regards
    Marc
    Jun 13, 2019 @ 12:43
    Bo Jacobsen
    Hi Marc.
    Thats exactly what we gonna do.
    Thanks.
