I'm having an issue where I have nested content that contains a multi-node picker that is has a maximum number of items is set to 1.
I'm trying the following, but the link won't show because I think it returns a null even when I have published links in the content.
<!-- Features --> @{ var features = Model.Value<IEnumerable<IPublishedElement>>("productFeatureList"); <section class="container mb-3 mt-3"> <div class="row pb-4"> @foreach (var feature in features) { <div class="col-lg-4 col-sm-6 mb-30 pb-4"> <div class="card"> <div class="card-body"> <h4 class="card-title">@feature.GetProperty("featureBenefit").Value()</h4> <p class="card-text">@feature.GetProperty("featureDescription").Value()</p> @{ var moreLink = feature.Value<IPublishedContent>("featureMoreLink");} @if (moreLink != null) { <a href="@moreLink.Url" class="btn btn-gradient mt-2">@moreLink.Name</a> } </div> </div> </div> } </div> </section> }
Have you tried to get the raw value to see what is stored in "featureMoreLink"?
Just use feautre.Value("featureMoreLink"), maybe like this:
@if (moreLink != null) { <a href="@moreLink.Url" class="btn btn-gradient mt-2">@moreLink.Name</a> } else { <text>@feautre.Value("featureMoreLink")</text> }
Thanks for the suggestion. I tried it out with the code below and it definitely displays the results of the "else" part of the statement as: Umbraco.Web.Models.Link
I'm not sure what do next.
@{ var moreLink = feature.Value<IPublishedContent>("featureMoreLink");} @if (moreLink != null) { <a href="@moreLink.Url" class="btn btn-gradient mt-2"><i class="fe-icon-@feature.GetProperty("fontIcon").Value()"></i> @moreLink.Name</a> } else { @feature.Value("featureMoreLink") }
This makes sense :)
I can't say why your multi-node picker stores a Link (sure it's not a multiurlpicker?), but if you change the type, it should work:
@{ var moreLink = feature.Value<Umbraco.Web.Models.Link>("featureMoreLink");} var fontIcon = feature.Value<string>("fontIcon"); if (moreLink != null) { <a href="@moreLink.Url" class="btn btn-gradient mt-2"><i class="fe-icon-@fontIcon"></i> @moreLink.Name</a> } }
It is a Multi Url Picker. Your help did the trick. I'm still learning how to change the type on things, so I needed an example like that.
Here's the final code that worked:
<!-- Features --> @{ var features = Model.Value<IEnumerable<IPublishedElement>>("productFeatureList"); <div class="row pb-2 pt-4"> @foreach (var feature in features) { <div class="col-lg-4 col-sm-6 mb-30 pb-4 d-flex align-items-stretch"> <div class="card"> <div class="card-body"> <h4 class="card-title">@feature.GetProperty("featureBenefit").Value()</h4> <p class="card-text">@feature.GetProperty("featureDescription").Value()</p> @{ var moreLink = feature.Value<Umbraco.Web.Models.Link>("featureMoreLink"); } @if (moreLink != null) { <a href="@moreLink.Url" class="btn btn-gradient mt-2"><i class="fe-icon-@feature.GetProperty("fontIcon").Value()"></i> @moreLink.Name</a> } </div> </div> </div> } </div> }
We are all still learning ;-)
Happy I was able to help
How to make Multi-Url Picker work in Nested Content
Just use
feautre.Value("featureMoreLink"), maybe like this:Thanks for the suggestion. I tried it out with the code below and it definitely displays the results of the "else" part of the statement as: Umbraco.Web.Models.Link
This makes sense :)
