I was wondering if there is any easy way to select a partial to render in the grid layout. To make it as dynamic as possible i want to let the umbraco user select what property should be rendered in the section e.g. rich text editor, image etc.
Example
This is just an illustration, it does not work.
first you select the partial content type
Then you select which partial you want to be rendered in the grid
from the Partial Views folder
I hope you know what i mean, else let me know and i will try to rephrase my issue. Any improvement or ideas is more than welcome
Grid layout partial render
Hello forum,
Example This is just an illustration, it does not work.
There is no such library ?
