Strongly Typed Model for Composition and Child Node
We're creating a baseline site and I'd like to find a way of creating re-usable page elements, e.g. a Call to Action which can be used either as a composition on one type of page where it's static or as a child of another type of page so it can be sorted.
I'm aware I could use the grid for the sorting, but wondered if there is a way of building the partial view so it can be used for both.
If I reference the model using View Page @inherits UmbracoViewPage
If I reference the interface @inherits Umbraco.Web.Mvc.UmbracoViewPage
Your code examples don't appear to have come through properly, but I'm assuming you had something like this:
@inherits UmbracoViewPage<IMyComposition>
These two variations?
@inherits UmbracoViewPage<MyComposition>
I think you should be able to use the second version to handle both composition behaviour and full page rendering, although you might need to do a cast in order to get it to work. This is because MyComposition will inherit from IMyComposition which might allow you to pass between the two.
Is there a way I can do both?
Hey Kerry,
MyCompositionwill inherit fromIMyCompositionwhich might allow you to pass between the two.I've not tested this so it's just a theory.
Nik
