  • Karen 8 posts 98 karma points
    Jul 12, 2019 @ 10:08
    Karen
    Site navigation
    Hello, I am trying to create a two level navigation for my site. I have changed the order of the code and get various error messages the latest being error -
    CS1928: 'System.Collections.Generic.IEnumerable ... does not contain a definition for 'Any'
    I also get the name secondLevel does not exist in the current context even though the var is above the code block where it will be used.
    I'm very confused if someone could explain why the code below is not working I would be very grateful.
    The code from the Template linking to this partial is @Html.Partial("V6NavigationTopLevel-2")
    Thank you
    @* Displays child pages below the root page of a standard website. *@
    @* Get the root of the website *@
    var root = Umbraco.AssignedContentItem.AncestorOrSelf(1);
    var firstLevel = root.Children.Where("Visible");
    @* dispaly first level *@
    foreach(var sectionPage in firstLevel)
        <ul role="navigation" aria-label="Primary" class="nav navbar-nav">
            <li>
                <a href="@sectionPage.Url">@sectionPage.Name</a>
                @* display secon level *@
                @if (sectionPage.Children.Any("Visible"))
                    var secondLevel = sectionPage.Children.Where("Visible");
                    <ul aria-label="Secondary" class="">
                        @foreach (var subSection in secondLevel)
                            @* display subSection here *@
                            <li>
                                <a href="@subSection.Url">@subSection.Name</a>
                            </li>
                    </ul>
            </li>
        </ul>
    Jul 12, 2019 @ 11:10
    Karen
    Hi, I have the solution - you can't place the Visible in the any() it needs to go in the where() and then you activate the boolean any. So the correct code is: -
    @* Second level *@
            <li>
                @if (sectionPage.Children.Where("Visible").Any())
                            // display subSection here
                            <li>
                            </li>
                    </ul>
            </li>
        </ul>
    Thank you, I hope this is useful for others :)
