I am new to this, I'll try my best to describe the issue I have, apologies in advance if I'm not making sense.
I need to create a new template to show (the same) content across various devices, the template needs to be able to shift its design based on context of where it is viewed using URL query parameters.
Looking at the "Relate to Original" feature there might be an easy way to achieve this providing the "Relate to Original" feature left you pick different templates and will only "relate" the actual content when used?
Or, does the "Relate to Original" mean I have to use the same template across all pages?
Hope that makes sense. Appreciate your insights, if you have a better way to achieve the above that would obviously be greatly appreciated. .
Relate to Original
Thanks!
